Electric Field and a Charged Cork Ball on a Massless String
A charged cork ball with a mass of 1g is suspended in a uniform electric field of E = (3i + 5j) * 10^5 N/C, achieving equilibrium at an angle of 37 degrees. To find the charge on the ball and the tension in the string, the forces acting on the ball must be analyzed, including the electric force (F(electric) = qE) and gravitational force (F(grav) = mg). The equilibrium condition requires resolving the gravitational force into components, where mg*cos(θ) provides tension and mg*sin(θ) counteracts the electric force. The electric force's components can be expressed using the angle formed with the string, leading to equations that relate tension and charge. Solving these equations will yield the values for the charge on the ball and the tension in the string.
gsquare567
A charged cork ball of mass 1g is suspended on a light string in the presence of a uniform electric field. When E = (3i + 5j) * 10^5 N/C, the ball is in equilibrium at \theta = 37 degrees. Find the charge on the ball and the tension on the string.
|\theta\
| \ / <- uniform electric field, E = (3i + 5j) * 10^5 N/C
| O <- charged cork ball, mass = 1g, q = ?
i
-------> j
F(electric) = qE
F(grav) = mg(-j)
I tried using the cosine law with the forces to isolate for \theta
a^2 = b^2 + c^2 -2bc * cos(\alpha)
but it canceled out.
Anyways,
\alpha = \theta
a = F(elec)
b = F(grav)
c = F(res) = F(elec) + F(grav)
Any ideas? Thanks!
In the equilibrium position, resolve mg into two components.
mg*cosθ will provide the tension and mg*sinθ will try to bring the string into vertical position.
The magnitude of the electric field is sqrt(34) and makes an angle α = arctan(5/3)
The electric force on the cork ball is q*E.
In the equilibrium position angle between the string and the electric force is (90 +α - θ )
Its component along the string is Fe*cos(90 +α - θ) and perpendicular to the string is Fe*sin(90 +α - θ ).
Equate them with the components of mg and solve for T and q.
