Volume by Slicing: A cylindrical wedge, help needed please
RolloJarvis
Find the volume of curved wedge that is cut from a cylinder of radius 3m by two planes. One plane perpendicular to the axis of the cylinder, the other plane crosses the first plane at a 45 degree angle at the centre of the cylinder.
(Hint: let the line of intersection of the two planes be the y-axis and then the cross section of the slice is a rectangle whose area you need to find as a function of x)
V = \int^{b}_{a}A(x) dx
I need to find the area of the rectangle described above as a function of x so i can integrate it to find the volume.
The length of the vertical sides of the rectangle will given by the function y=x/2, and i presume the horizontal sides would be some function involving sin, seeing as is starts at 0, ends at 0, and has a maximum or 2r in the middle of the cylinder... but i can't figure it out. this is the bit I am stuck on.
Thanks for the help!
It's always a good idea to draw a picture. Maybe this will help
It isn't clear from your post whether you also want the back half, which would double the answer.
of course! that makes a lot more sense with the picture, out of curiosity, what program did you use to draw the diagram? I do a lot of lab reports and a good drawing package would be very useful.
I will post a new attempt at an answer when i get the chance.
in regards to the back half also, I am unsure as all the information i have been given is written above. i guess i will just write each half = ... explicitly on the answer sheet.
It's called Mayura Draw:
http://www.mayura.com/
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
