Calculating Film Thickness on Rotating Cylinders with Fluid Gap?
  • Thread starter Thread starter Samy1977
    Cylinders Fluid
The discussion centers on calculating the film thickness on two rotating cylinders with a fluid gap between them. The cylinders, which do not touch, operate at different speeds, affecting fluid distribution. The Navier-Stokes equations are suggested as a potential method for calculation, though they may be complex for manual computation. Participants recommend using commercial Computational Fluid Dynamics software, like Fluent 6.0, for accurate simulations. Experimental measurements and integral conservation laws are also proposed as alternative approaches to determine the film thickness.
Samy1977
I am trying to solve a problem concering roll coating. This is 2 rotating cylinders whith different speeds. The two cylinders are in the same horizontal plane. They don't touch each other, but are close together. On one cylinder there is a fluid. When the fluid goes through the gap, the point where the cylinders are closest to each other, both cylinders take some of the fluid. Is it possible to calculate how thick the film is on each cylinder??
I have looked a month at this problem now. I think it can be done with the Navier-Stokes formulas, but they could be too difficult to calculate manualy. I know it abolutely has something to do with the speed of the cylinders, and probably the gap between them.
Sorry but I cannot imagine your problem. Do you mind posting a picture of it?. It can be done in .bmp and clicking below in Manage Attachments. I don't know if the cylinders are concentric, parallel, and I don't understand what you mean with the closest point and "both cylinders take some of the fluid".
stage.bmp]The problem[/URL]
At the top you see how the cylinders are located to each other. In the close up, the red is the fluid. One cylinder has all the fluid first, then it is divided between the two cylinders. I want to "know"/calculate the thickness one cylinder 1. Between the two blue arrows.
Hope it is clearer now. Sorry about the description, it is a bit difficult to describe.
Wow!
I'm sorry. To be honest, I think your problem is very difficult to be solved in a classical way. I will explain that:
Making your own numerical simulation with the N-S equations will be a serious challenge. It's a viscous free surface flow. The free surfaces flow are heavier to simulate, because you need a boundary condition between the fluid and the air.
My advice, if you want to listen it, is to use a commercial simulation software of Computational Fluid Dynamics. Surely Fluent 6.0 can solve your problem.
Your question is not trivial at all. :bugeye:
Another posibility would be to measure experimentally some fluid variables and to obtain the thickness by means of integral conservation laws.
Thanks, that is what I thought. I had to verify.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
