What factors determine the viability of regenerative power plants?
  • Thread starter Thread starter El Moriana
    Plants Power
The viability of regenerative power plants is influenced by factors such as steam extraction efficiency, thermal efficiency, and the balance between capital and operating costs. While regenerative systems improve thermal efficiency through feedwater heating, they also introduce complexity and increased costs. The optimal range for size, pressure, and temperature in these plants is crucial for maximizing benefits. Ultimately, the decision to implement regenerative technology hinges on a cost-benefit analysis comparing initial investment against long-term operational savings. Understanding these dynamics is essential for determining when regenerative power plants are a feasible option.
El Moriana
Hi, this question is posed merely out of curiosity:
Background
My thermodynamics textbook tells me that in regenerative power plants (i.e. ones making use of feedwater heaters), the steam extracted during expansion in order to feed the feedwater heater(s) results in less work being developed in the subsequent stages of the turbine. It then tells me that in practice, the systems are such that the advantage of the water heater ends up being greater than the lost turbine work.
Question
This leads me to assume that there is a range in size/pressure/temperature in which regen power plants are viable. What is this range? (this question could also be answered by telling me situations in which regen plants are not viable)
There is a simple answer, cost.
Steam extraction and feedwater heating is always good for thermal efficiency of closed-cycle plants. (open-cycle plants are another exception.) But they add complexity and cost. So in the end it comes down to capital cost and development time verus operating costs.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
