How Accurate is My Solution for IC and VCE in a Silicon Transistor Circuit?
  • Thread starter Thread starter martyg314
    Circuit Transistor
martyg314
This is for a 300 level electronics lab class and I'm wondering if I'm close:
If the following silicon transistor (VBE = 0.6 V) has a B value of 100, determine IC and VCE.
http://img862.imageshack.us/img862/80/circuit1.th.jpg
Uploaded with ImageShack.us
First I found an expression for \alpha (0.99) and noted that
VBC=VCE-0.6
Then I used Kirchoff's laws for the BE loop and the "loop" from the -15 V down to ground:
BE Loop:
-15 + 2000IC + VCE + 1000IE = 0
-15 + 2990IC + VCE = 0
15 V to Ground:
-15 + 40000IB +VBC + 2000IC = 0
-15.6 + 2400IC + VCE =0
I then solved these equations to get:
IC = 1 mA
VCE = 18.04 V
Any tips would be greatly appreciated.
Also, if anyone can recommend a good electronics text. Mine (Principles of Electronic Instrumentation by Diefenderfer) is filled with errors and is short on example problems.
Thanks,
MG
It might be profitable to replace the base bias network with a Thevenin equivalent. Then the only loop you need to concentrate on will be the one containing the base-emitter.
Emitter current should be IE = IB(β + 1). Then, knowing VBE = -0.6V, you should have everything required to solve for IB, thence IC.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
