Triple Integrals: Solving \int\int\int^{}_{B} ye^(-xy) dV
shards5
\int\int\int^{}_{B} ye^(-xy) dV where B is the box determined by 0 \leq x \leq 4, 0 \leq y \leq 1, 0 \leq z \leq 5.
\int^{4}_{0}\int^{1}_{0}\int^{5}_{0} ye^(-xy) dzdydx
Integrating the first time I get
zye-xy
Plugging in 5 and 0 I get
5ye-xy
Integrating the above with respect to y. I use u = 5y and dv = e-xy which gives me du = 5du and v = \frac{-e^(-xy)}{x}
Which leaves me with the following equation.
-5y*\frac{e^(-xy)}{x} - \int e^(-xy)5du
After integration I get
-5y*\frac{e^(-xy)}{x} + \frac{5e^(-xy)}{x}
Plugging in 1 and 0 into the above I get
-5\frac{e^(-x)}{x} + 5\frac{e^(-x)}{x} - 5\frac{e^0}{x}
Which just leaves me with since the first two cancel each other out.
-5\frac{e^0}{x}
Integrating the above I get
-5log(x) which is where my problem lies, I can't get the log of 0.
Let's fix up the latex a little. For exponents, use e^{-xy} instead of e^(-xy).
\int\int\int^{}_{B} ye^{-xy} dV where B is the box determined by 0 \leq x \leq 4, 0 \leq y \leq 1, 0 \leq z \leq 5.
\int_0^4 \int_0^ 1 \int_0^5 ye^{-xy} dzdydx
= \int_0^4 \int_0^1 \Bigr|_0^5 zye^{-xy} dzdydx
= \int_0^4 \int_0^1 5ye^{-xy} dydx
At this point, I think it would be simpler to integrate with respect to x.
Didn't even think about that . . .but for some reason it doesn't seem to be working.
I switched the integration around and got the following.
\int_0^1 \int_0^4 5ye^{-xy} dxdy
After the first integration it comes out really neatly as
-5e-xy
and after plugging in 0 and 4 I get
-5e-4y
5/4e-4y
but after plugging in 0 and 1 I get the wrong answer, not sure what I am doing wrong.
-5e-xy
-5e-4y
5 e^{-(0)(y)} isn't zero.
I guess I shouldn't have rushed through the calculations as I did, thanks a lot for pointing out my mistake.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
