How Do You Solve the Ice Cube and Spring Problem on a Slope?
  • Thread starter Thread starter eliassiguenza
    String
The discussion revolves around solving a physics problem involving a 54 g ice cube on a 35-degree slope, compressed against a spring with a spring constant of 27 N/m. The original poster attempted to calculate the motion using force equations and kinematic formulas but encountered errors in their approach. Suggestions were made to utilize conservation of energy principles to simplify the problem and accurately determine the maximum distance the ice cube travels. The importance of clearly defining the desired outcome of the calculations was also emphasized. Overall, the conversation highlights the need for a structured approach to solving physics problems involving forces and energy.
eliassiguenza
String Problem! Please Help!
A 54 g ice cube can slide without friction up and down a 35 degree slope. The ice cube is pressed against a spring at the bottom of the slope, compressing the spring 12 cm. The spring constant is 27 N/m
F = -kx
F = ma
soh cah toa
PE = -1/2 kx^2 = 1/2 mv ^2
x = Vt+1/2at^2
I did the following and I got it wrong .. any ideas?
F= k * x
PE = 1/2 k * x^2 = m*v^2
V^2 = P.E./(1/2 * m) = Square Root of that to get V.
mass * cos of angle = to find the force keeping the block of ice on the ground.
mass * sin of angle = to find the parallel force, which pulls on the ground ...
- Parallel Force/ mass = acceleration of the ice block.
using Kinematic equations I determined the time it'll take to do the whole thing... without the spring anymore just to go up and down where it started..
I divided that time because it obviously plots a parabola... and that's when it stops to come back.. that value of time i used in... V t + 1/2 at^2 to find distance ... but
i got it wrong .. any ideas?
Your problem statement did not specify what it is you want to calculate!
hi eliassiguenza! :smile:
(try using the X2 icon just above the Reply box :wink:)
eliassiguenza said:
… I divided that time because it obviously plots a parabola... and that's when it stops to come back.. that value of time i used in... V t + 1/2 at^2 to find distance ...
if you're trying to find the maximum distance, why not just use conservation of energy? :smile:
