Calculating Power Radiated & Energy in Magnetic Loop
The discussion focuses on calculating the power radiated by a light bulb connected to a magnetic loop and the total energy emitted, emphasizing the relationship between speed and energy consumption. The power through the bulb is derived as (B^2 L^2 a^2) / R, while the total energy is calculated as (B^2 L^2 a X) / R, showing a direct dependence on the speed of compression. A key point raised is the confusion regarding why faster compression seems to require more energy despite a shorter duration for energy dissipation. The explanation clarifies that although the power increases with velocity squared, the energy radiated still increases overall with speed due to the linear decrease in duration. The conversation concludes with an acknowledgment of the mathematical derivation and its implications.
EEWannabe
A Loop of height L and initial width X is placed in a magnetic field and the plane of the loop is perpendicular to the field, the loop is connected to a light bulb of resistance R. By applying a force F to the left hand side of the loop it can be compressed at a constant rate dx/dt = -a.
Calculate the power radiated by the lightbulb.
Calculate the total energy emitted by the lightbulb, does it depend on a? Comment on the answer with reference to the force F.
http://img859.imageshack.us/img859/2079/faraday.jpg
E = - d(flux)/dt
So since the flux = BA (sin90) = BA = BLx, d(flux)/dt = BLdx/dt = BLa
So E = -BLa. This means the power through the bulb = E^2/R = (B^2 L^2 a^2) / R.
And the overall energy is Power * Time = ((B^2 L^2 a^2) / R) * (X / a) = (B^2 L^2 a X) / R
And comparing this to the energy used by the force.
P = Fv = BIL a, from above the I is given by E/R = BLa/R so P = B^2 L^2 a^2 / R. So it's the same result.
However! I can't come to terms with this result, I don't see how doing it quickly will use more evergy than doing it slowly. I don't see why to the overall energy the speed, a, makes a difference?
Maybe this is trivial, or maybe I've made a mistake with the algebra, but anyone clearing this up would be most appreciated!
Excellent work EEWannabe, looks great.
You've shown that the EMF is proportional to the velocity. I.e. the faster the flux changes, the more voltage is produced. On the other hand the faster it moves the less time there is to dissipate energy. BUT---the power goes as the velocity squared, while the duration decreases linearly with a; thus, overall, the energy radiated still increases with velocity.
Does that help at all?
Ah I've gotcha, I guess I was getting confused as I wasn't confident in the maths and I carried on thinking about the argument you outlined.
Thanks a lot for the help!
Happy to help; your derivation was really sharp, couldn't have been done better.
