Finding/Implementing a digitally-controlled high-voltage switch
  • Thread starter Thread starter Marco Polo
    Switch
A user is seeking a digitally-controlled high-voltage switch capable of operating at frequencies between 100 Hz and 100 KHz, with a control signal of 3 to 12 volts and a switching voltage of 0 to 5 kilovolts DC. There is a discussion about using high-powered transmitting tubes, though concerns are raised regarding their frequency capabilities, as many operate at lower frequencies. Suggestions include looking for second-hand tubes on platforms like eBay or at Ham Radio events, as new ones can be quite costly. The conversation emphasizes the need for a cost-effective solution under $100 per switch while meeting specific technical requirements. Overall, the search for suitable components continues with a focus on both performance and affordability.
Marco Polo
I am looking for a switch or relay to switch high voltages on and off based on a digital input signal. Below are the characteristics of the device I would like to find.
Switching frequency: 100 Hz to 100 KHz
Input (control) signal: square waves, 3 to 12 volts amplitude, 100 Hz to 100 KHz range
Input voltage to be switched: 0 to 5 kilovolts DC, 1 milliamp (max)
Output signal: square waves, 0 to 5 kilovolts amplitude
Load: capacitive load (several picofarads)
Cost: not more than $100 per switch
Thanks for any info you can contribute to this!
skeptic2, thanks for the reply. Do you know if these tubes will will operate at a frequency of up to 100 KHz at a voltage of 5 KV? Taking a look at the link provided, it seemed that the tubes operate at only a few hundred hertz? Or maybe I did not interpret the headings correctly?
Also other ideas are welcome from anyone.
Those maximum frequencies would be in MHz. ie 200 MHz is 200 000 000 Hz. So, 100 KHz would be no problem.
These are high powered transmitting tubes and they are usually very expensive if you buy them new.
You may be able to hunt for second hand ones on Ebay or at Ham Radio gatherings.
vk6kro, thanks for the info!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
