What is the Time to Reach a Distance of 50 ft at a Velocity of 60 mph?
lilac1.
1. A pitcher throws a baseball at 60mph. How much time does it take the ball to reach the batter 50 ft away?
2.t = x/v
3. t = 50/60
t = 0.83
Your units are not consistent (miles,feet). If you stated your units for time (hours) you would see a ridiculous result :smile:.
