How to Identify a Metal Using Work Function and Wavelength?
To calculate the work function of a metal using the photoelectric effect, the key equation to use is E = hf - φ, where E is the energy of the emitted electrons, hf is the energy of the incoming photons, and φ is the work function of the metal. Given a wavelength of 200.0 nm, the energy of the photons can be calculated using the formula E = hc/λ, where h is Planck's constant and c is the speed of light. Once the energy of the photons is determined, the stopping potential (3.33 V) can be converted to energy using E = eV, where e is the charge of an electron. The work function can then be found by rearranging the initial equation to φ = hf - eV. This process allows for the identification of the metal based on its work function, which is a characteristic property of each metal.
geej77
Calculating Work Function
I am having trouble identifying a metal (based on its work function) given the wavelength and stopping potential. I will give more specifics below but can anyone help me with useful formulas to make this a little more streamlined in the future? Thanks!
Ultraviolet radiation with wavelength 200.0 nm hits a metal and electrons are emitted, which can be stopped by a potential of 3.33 V. What is the work function/identity of the metal?
Chemistry news on Phys.org
Start with the equation describing photoelectric effect. You will need to convert between different ways of expressing energy, other than that it is just a simple plug and chug.
Thanks I will give it a shot!
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
