Freezing point depression constant value clarification.
In a discussion about calculating the molar mass of an unknown solute using freezing point depression, a tutor seeks clarification on an issue where the final molar mass calculation yields a negative value due to the negative freezing point depression constant (Kf). The tutor understands the equations involved but is confused about the negative outcome for molar mass, which should be positive. The conversation highlights that both the change in freezing point (ΔTf) and Kf are negative, but the resulting molar mass remains positive because it is derived from the ratio of two negative values. The tutor questions whether using the absolute value of Kf would resolve the issue, suggesting that this approach would yield a positive molar mass as expected.
LexLuthor
Hi all,
I just need a little clarification here, please. I'm a tutor and I've been helping a student with their freezing point depression lab and the student has to determine the molar mass of an unknown solute from the experimental data provided. I understand the process and have been able to work all of the equations and explain them to the student without any problems except for one. When the final calculation is made to determine the molar mass of the unknown solute it comes out negative because the Kf provided is negative. That makes sense since it's a freezing point depression constant. However, it does not make sense for a molar mass to be negative. My question is when using the Kf value provided should it just be the absolute value of the Kf? That would make sense because then the molar mass would come out positive as we would expect a molar mass value to be. Any clarification that can be provided will be appreciated. Thanks for taking the time to read this.
- Lex
Chemistry news on Phys.org
LexLuthor said:
Hi all,
- Lex
\Delta T_{f} = K_{f}m
\Delta T_{f} and K_{f} are both negative, but the molar mass is still positive, since it is the ratio of two negative numbers.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
