Linear Algebra: intersection of subspaces
TheTangent
I'm working on a problem that involves looking at the dimension of the intersection of two subspaces of a vector space.
M \subset V
N \subset V
dim(M \cap N)
[\vec{v}]_{B_M} is the coordinate representation of a vector v with respect to the basis for M
I reformulated M \cap N in a bunch of different ways that would be too long to copy down here, but I finally came to this (which may or may not be useful to me in my larger problem but I'm wondering if it is valid itself):
\vec{v} is itself, so it must have the same dimension in both M and N, and since the bases are ordered, for each \vec{b}_{Mi} in B_M for which the corresponding scalar is not zero in the linear combination of elements of B_M equal to \vec{v}, and each \vec{b}_{Nj} in B_N for which the corresponding scalar is not zero in the linear combination of elements of B_N equal to \vec{v}, if i=j then \vec{b}_{Mi} and \vec{b}_{Nj} are dependent
and [\vec{v}]_{B_M} has zeros in the same places as [\vec{v}]_{B_N}
but there is a major problem here with the fact that we may have dimM ≠ dimN
first imaging a basis for the intersection {b1,b2,...,bp}, then expand it to a basis of M, {b1,b2,...,bp,m1,m2,...,mq},
also expand it to a basis for N, {b1,...,bp,n1,n2,...,nr}, dimension of the intersection is p, dim(M)=p+q, dim(N)=p+r.
beautiful
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
