Need help:How to measure stress on a bridge.
To measure stress on bridge models, using a strain gauge is recommended as it allows for deriving stress from strain in the bridge members. Alternatively, a load cell can be used, though it may be more complex and costly. The discussion also suggests measuring deflection at critical points to calculate stress indirectly. It's important to consider the material of the model bridge when selecting measurement methods. Overall, researching these options will help determine the most effective approach for the project.
zyedy
I am doing a science project which i have to measure the stress put on the models of 3 different kinds of bridge, and was wondering what the most efficient way to measure the force per square area.
Thanks.
We'll need more details. Do you know what the forces are, so you can calculate the stresses, or do you want to directly measure stresses of the member ?
The best way I know to measure stresses like these is by using a strain gauge and deriving the stress from the strain in the member. Another option, is using a load cell, but that may be more expensive and harder to work with (but I could easily be wrong, and this might be just what you need).
I suggest you google both options and decide what will work best for you.
I need to measure the amount of compression and tension on the surface of a model bridge deck, and I am not sure what the model will be made of yet, thank you though ill try that.
One pretty simple additional option could be to measure, say, deflection at some point (typically maximum) and use that to calculate the stresses.
