What is the rotational kinetic energy of one molecule of Cl2
The discussion focuses on calculating the rotational kinetic energy of a Cl2 molecule using the formula K = 1/2(m)(r^2)(w^2). Participants note that the initial approach yields incorrect units and suggest using the moment of inertia formula K = 1/2Iω^2 instead. The moment of inertia for the Cl2 molecule is derived from its atomic structure, requiring the mass of a single chlorine atom in kilograms. Clarifications emphasize the importance of using consistent units and correctly identifying the radius of rotation. The conversation concludes with encouragement to recalculate using the corrected parameters for accurate results.
Kawrae
In a crude model of a rotating diatomic molecule of chlorine (Cl2), the two Cl atoms are 2.00e-10 m apart and rotate about their center of mass with angular speed w = 1.40e12 rad/s. What is the rotational kinetic energy of one molecule of Cl2, which has a molar mass of 70.0 g/mol?
>> I wasn't exactly sure how to do this, so I thought I'd try with the rotational kinetic formula from the first half of General Physics. That formula was 1/2(m)(r^2)(w^2). I don't think it gave me the answer they were looking for... it wants an answer in Joules and I'm not sure where to start or how to finish it. Or if this is even along the right steps to take...
Okay... I have:
r=2.00e-10 m
w=1.40e12 rad/s
m=70.0 g/mol
1/2 m(r^2)(w^2)
= 1/2 (70)(2.00e-10)^2(1.40e12)^2
= 2.74e6 J
Hmmm... is r wrong? Or should I change w to degrees? I'm not sure what to do...
Kawrae said:
Okay... I have:
r=2.00e-10 m
w=1.40e12 rad/s
m=70.0 g/mol
1/2 m(r^2)(w^2)
= 2.74e6 J
It's good practice to include the units when showing your working. Correcting your working,
K = 1/2 (70.0 g/mol)(2.00e-10 m)^2 (1.4e12 rad/s)
= 2.74e6 g m^2/mol/s.
Now, I'm not sure what the significance of that derived unit is, but it's certainly not energy :wink:.
Your equation K = \frac{1}{2}Mr^2\omega^2 is clearly wrong as it is dimensionally inconsistent --- one side has units of kg m^2/s^2 and the other has g m^2/mol/s. The equation you're looking for is K = \frac{1}{2}I\omega^2 where I is the moment of inertia of the rotating body. The equation for the moment of inertia of a continuous body is I= \int r^2\, dm, which, for the Cl_2 molecule is given by the discrete sum I = (1.00E-10 {\rm m})^2 m + (1.00E-10 {\rm m})^2 m. To find the value of m, use the relationshipsn = \frac{m}{M} and n = \frac{N}{N_\mathrm{A}}. That should be all the info you need to complete the question.
P.S. Avoid using degrees at all in physics, except in particular disciplines such as astronomy.
Hi Kawrae,
In my opinion you are not so wrong with your approach. E_c=(1/2)*m*v^2 must work for all physical systems. When you have two particles in system you must add the two corresponding energies. But, m must be the mass of the particle (in Kg) and v=r*w where r is the radius of the trajectory (and not the relative distance between particles). So, you have
E_c=(1/2)*m*(r/2)^2*w^2+(1/2)*m*(r/2)^2*w^2=m*(r/2)^2*w^2=(1/4)*r^2*w^2
(here r is the distance between the two particles...then r/2 is the radius of the trajectory)
Now you have to calculate the mass m of a single atom (see the post of jdstokes).
Good luck!
