What is the relationship between spring stiffness and length?
  • Thread starter Thread starter jsmith613
    Frequency Spring
The relationship between spring stiffness and length indicates that shorter springs can exhibit higher stiffness, but this is not a universal rule. When a spring is stretched, the amount of extension is distributed across its length, affecting the effective spring constant. A shorter section of a spring will have a higher spring constant compared to a longer section of the same material. Additionally, the concept of Young's Modulus is relevant, as it measures material properties regardless of the spring's length. Understanding these principles is crucial for accurately analyzing spring behavior under load.
jsmith613
look at attachment
so we know that the frequency of a spring is given by
f = \frac{1}{2 pi} \sqrt{\frac{k}{m}}
so the answer should be A
BUT the answer is C. why?
Why do you think the answer should be A? How would adding an inelastic string affect the variables described by the
f = \frac{1}{2 \pi} \sqrt{\frac{k}{m}}
equation?
equation?
surely it affects spring consttant?
how does changing the length of the spring change k??
although F = kx
F/x is constant for a particular string
although F = kx
A strong spring will be extended a small amount when a load m is attached.
A weak spring will be extended a large amount when a load m is attached.
Suppose the original spring was extended 10cm by the load m
That means each half was extended 5 cm by the load m.
Thus in example C, the load m extends the piece of spring only 5cm. the half spring behaves as a stronger spring that the whole spring.
In example D, each of the springs will be extended 10cm by the load - so a total extension of 20cm. The double spring behaves as a weaker spring than a single spring.
so basically I have to know that a shorter spring is stiffer than a longer spring?
To say that short springs are stiffer than long springs is not strictly correct.
I think you will find that the 30 cm spring from the front suspension of a car is much stiffer than the 10cm spring in a laboratory "spring balance"
Instead, you have to note that when a spring is stretched by a load, a fraction of that spring stretches only a fraction of that amount.
When that is applied to compute a spring constant, it means that if you have two sections of the same original spring, the shorter section will have a higher spring constant.
When you study materials, you will come across the concept of Young's Modulus. That is a measure that is used to show that two samples have basically the same material properties, despite the fact that one of them is extended more in an absolute sense.
cheers
