Trying to Understand Light in Motion: A Frustrating Puzzle
In summary, the train cabin should receive light from both the front and back of the train at the same time. However, it is difficult to understand how to make this happen.
  • #386
solarflare said:
that is true
but A and B are still the source for what both frames see
and C is the position of the observer when they see it - they do not see it at A and B
C is at the position of the train observer. C represents the event of the light from each end reaching the train observer.
So what?
  • #387
So what?
so that means that A and B are the source of the light
  • #388
and as the sources are both at t = 0
then they must be simultaneous
  • #389
Simultaneous according to whom?
  • #390
cepheid said:
I made this spacetime diagram a while ago, and I *think* it corresponds to the original scenario that is being discussed here. Maybe it will help. The "worldline" of the train (which is its path through spacetime) is clearly indicated, and it of course coincides with the t' axis:
The worldline of the photon that is coming in from the front (i.e. from the positive side) clearly intercepts the worldline of the train before (i.e. at a smaller value of t') the worldline of photon that is coming in from the rear (negative side) does.
The coordinate grid I've drawn is for the train observer, in the primed (t',x') coordinate system.
this was posted to show the videos worldline
the strikes are along the X axis both at t = 0
as they occur on the train - they must be simultaneous
the light then travels from the sources to the platform observer at t = 4
the lines also cross the t prime line but the x prime line is not used to show where they cross on the t prime line
if the x-axis used to show the strikes for both frames then t = 0 is where they originated from for the t prime line
this means that they struck the train simultaneously in the trains frame also but the train moves forward to meet the front strike and away from the rear
  • #391
Once again, you have switched scenarios. This diagram is for the standard scenario in which the lightning strikes are simultaneous in the platform frame.
Yes, in the platform frame.
The fact that they occur 'on the train' is irrelevant. They are simultaneous in the platform frame, not the train frame.
Sure, it takes time for the light to travel to the platform observer.
the lines also cross the t prime axis but the x prime line is not used to show where they cross on the t prime line
You should be able to draw in the lines to see where and when the events (the lightning strikes) happen in the train frame.
  • #392
it is not irrelevant when the graph says they occur on the train simultaneously
and again the lines cross t prime from the source on the x-axis
if you want to say that t prime is relevant then the source of the lines that cross t prime must also be relevant
  • #393
This thread is obviously going nowhere (and very slowly at that). So it's time to shut it down.
Solarflare: All your questions have been answered several times over. Repeating the same thing isn't going to help. If you're serious, I suggest getting an intro book on relativity. (Or you can read Einstein's own words--see George's link.) Then you can go back and read through this thread again.
Thanks to everyone who contributed their time and effort to this thread.
