State-Space Representation with Initial Conditions: Finding the Right DSP Book
A recommendation for a DSP book that covers state-space representation with initial conditions is sought, emphasizing the importance of initial conditions. Initial conditions can be represented as the system's state at time n=0, influenced by its history from negative infinity to zero. The discussion suggests that resources in digital control theory may be relevant. Additionally, there is a focus on filtering and how initial conditions affect its outcomes. Finding a suitable text that addresses these concepts is essential for understanding the topic.
truva
Could you advise a DSP book which explains state-space representation with initial conditions. Initial conditions part is important for me. Thanks.
probably you're looking for a book in digital control theory.you can represent the initial conditions as the state of the system at time n=0 where the history of the system from -inf to 0 is what gets you these non-zero states at time 0.
No I am not related any of the control theory. I study filtering and the effects of its initial conditions.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
