Solving Pressure Question: Volume, Mass of Air @ 70F & 200psi
  • Thread starter Thread starter Frustra8ed
    Pressure
The discussion revolves around calculating the specific volume of air in a pressurized tank at 70°F and 200 psi. The user has determined the tank volume to be 2.1 ft³ but struggles with finding the mass of air and converting psi to lbf/ft². Responses suggest using the ideal gas law, specifically the equation Pν = RT, to find the specific volume. The universal gas constant for air is noted as 53.35 ft·lb_f/°R·lb_m, which is essential for the calculations. The user acknowledges the need for unit conversions to proceed with the problem.
Frustra8ed
I know this question is easy, but for some reason I am unable to figure it out.
The first part of the problem wants to know what the volume is in a pressurized tank. I figured it and it equals 2.1 ft^3.
The second part asks for the specific volume at 70 F and 200 psi.
So far all I have is v(specific volume) = V/m. Or 1/d = v
The gas in the tank is air, so basically I need to find the mass of air @ 70 F and 200 psi. I have the volume, so that is not the problem.
The answer to the question is .98 ft^3/lbm
Should I be using ideal gas laws? If I do use the ideal, I'm assuming I need to convert units. I'm having a problem converting psi to lbf/ft^2...
I can't come up with this answer, so if anyone can give me a hand I would appreciate it.
Thanks,
Frustr8ed, as the name states. :confused:
Thanks,
It would help if you would state the whole question. Use the ideal gas equation of state, PV=nRT to find n (number of moles). The answer won't be in ft^3/lbm.
AM
You may want to consider using this form of the ideal gas law:
P \nu = RT
where:
P = Pressure (Lb_{f}/ft^2)
\nu = Specific Volume (ft^3/Lb_{m})
R = Universal Gas Constant (for air: 53.35 Ft*Lb_{f}/°R*LB_{m})
T = Temperature (°R)
Thanks for the responses. I believe that last equation is the one I need to use, but I was having trouble converting units.
Thanks Again,
Frustra8ed
