Understanding Differentials: Deriving dε = F dot dr
Syrus
The proof begins: Suppose that F is conservative. Then a scalar field ε(r) can be defined as the line integral of F from the origin to the point r. So ∫F dot dr = ε(r), where the limits of integration are from 0 to r.
The next step, however, eludes me: From the definition of an integral, it then follows that an infinitesimal change in ε is given by dε = F dot dr.
Usually total differentials are related to partial derivatives, tangent planes, and Taylor expansions. I'm failing to fill in the intermediate steps in deriving dε = F dot dr from ∫F dot dr = ε(r) using the "definition of integral". Any insight?
Upon second thought:d/dr [∫F dot dr] = d/dr [∫F dot ndr] , where n is a unit vector in the direction of dr. So,
d/dr [∫F dot ndr] = d/dr [ε(r)]. Thus,
F dot n = d/dr [ε(r)]
and so, multiplying by dr:
dε(r) = F dot ndr = F dot dr
Is this valid?
Is this valid?
Close, but \mathbf{r} is a vector, and so an infinitesimal change in \epsilon ( \mathbf{r} ) is really
d\epsilon = \frac{ \partial \epsilon}{ \partial x} dx + \frac{ \partial \epsilon}{ \partial y} dy + \frac{ \partial \epsilon}{ \partial z} dz = \mathbf{ \nabla } \epsilon \cdot d\mathbf{r}
Hi gabbagabbahey! I understand that what you posted is the equation for the total differential, I am just struggling to understand how from ∫F dot dr = ε(r) (where the limits of integration are from 0 to r) one deduces the result- in particular, using the "definition of integral".
That is, how can we derive dε = F dot dr from what we have above?
Well, to me, the statement "From the definition of an integral" means using the fundamental theorem of calculus (FTC). For a simple one-dimensional integral, FTC tells you that if F(b)-F(a) = \int_a^b f(x) dx, then F'(x)=f(x) (or dF = f(x)dx).
For line integrals, this generalizes to the statement that if F(\mathbf{b}) - F(\mathbf{a}) = \int_{ \mathbf{a} }^{ \mathbf{b} } \mathbf{f} ( \mathbf{r} ) \cdot d \mathbf{r} regardless of which path you choose for the integration, then \mathbf{\nabla} F = \mathbf{f} ( \mathbf{r} ) (or, equivalently dF=\mathbf{f} ( \mathbf{r} ) \cdot d \mathbf{r})
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
