Calculate Thermal Resitance from Heat Sink Geometry
Calculating the thermal resistance of a heat sink involves understanding its geometry, material properties, and airflow conditions. Free convection complicates predictions, making direct measurement with a thermocouple and power resistors a more practical approach. While theoretical calculations are possible, they often require advanced knowledge and resources, such as textbooks on heat transfer. Comparing the custom heat sink to existing off-the-shelf profiles can also provide useful insights. Ultimately, practical measurement is recommended due to the complexities involved in thermal resistance calculations.
mcouch
Hi all,
I have a heat sink for which I know the exact geometry (have the CAD model). This heat sink was custom designed and machined from a hunk of aluminum, though it is very basic and I have a hunch I can find an extrusion or OTS part that will match its performance. Rather than trying to just match the surface area, I'd like to know what the thermal resistance of it is so that I can try to match it.
How do I calculate the thermal resistance of the heat sink given its geometry and material?
Here's a rough description of the heat sink:
18 square fins spaced evenly in a single row at a pitch of 0.36". Each fin is 2" tall by 2" wide and is 0.08" thick.
Thanks
mcouch said:
Hi all,
Thanks
The thermal resistance will depend on the orientation (horizontal or vertical), and whether there is forced airflow over it.
Often it is easier to just measure the thermal resistance θ with a thermocouple and power resistors...
I'm sorry, I forgot to mention: this is free convection. So I can make whatever assumptions I need to about ambient temperature, air density, air viscosity, etc.
It's about impossible to calculate, and certainly unreasonable, sorry. Measure it.
The heat exchange depends fundamentally on how much air circulates and how, which is already inaccessible to hand calculation and which computer programmes are bad at.
Add to it that the exchange is limited by the fine layer of air right against the metal that circulates less good... A few formulas are known for very simple shapes and that's all.
Some people specialize in that and, after months and years, are capable of giving an estimate. If you read French: Sacadura, "Initiation aux transferts thermiques". Hard, lengthy, and it won't help so much in a practical case.
Besides measuring, you could compare with existing similar heatsinks. Take a catalogue with data, say like Fischer, find the most resembling profile. By the way, I'm surprised someone machines a heat sink instead of cutting it from a bought profile.
Free convection is the most difficult to predict.
Engineering calculations w.r.t. fins and heatsinks (arrays of fins) are very possible and used often for things like electronics cooling and heat exchanger design. Unfortunately an internet forum isn't really the right place to try an teach someone how to do such calculations; you really need to take a college senior-level heat transfer class to do it.
Short of that, a textbook on the subject is a good reference on how such calculations are done, the textbook I have, Introduction to Heat Transfer, covers everything you need to do such calculations.
Suffice to say the general calculation procedure would be:
  • Conceptualize a thermal-equivalent circuit for the component being cooled, with thermal resistance variables for the heatsink, component, and convection.
  • Estimate ambient temperature and required power dissipation.
  • Using fin geometic properties calculate fin efficiency and thermal-equivalent resistance as a function of temperature. This would be accomplished using the "fin efficiency" for your particular geometry, out of a table in the book.
  • Plug the equation into the thermal-equivalent circuit and solve for the resulting temperature of the component and heatsink.
  • Iterate.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
