Engineering Circuits analysis with independent current source
The discussion revolves around circuit analysis using Kirchhoff's Current Law (KCL) and Kirchhoff's Voltage Law (KVL) to solve for voltages and currents in a given circuit. The user initially calculates the voltage at a node and derives values for various currents and power in circuit elements but realizes their calculations may be incorrect. Specifically, they find inconsistencies in their KCL application, particularly with the equation A + (A-4)/3 = 8. The user expresses frustration over their mistakes and seeks further assistance and solutions for additional problems. The thread highlights the common challenges faced in circuit analysis and the importance of accurate application of fundamental laws.
intelwanderer
https://www.edx.org/static/content-mit-6002x/images/circuits/H1P2.79e52b492b94.png
It's been a while since I've done KCL/KVL, could be that I'm being just being stupid.
I'm trying to find v1, i4, and the power in all the circuit elements.
I just used KCL at the top node and got 5 as the voltage. I called the top node "A". A + (A-4)/3 = 8.
From there, I got that v1 equals 5 V because there is no resistor there(which is wrong), and the values of i1-3(16/3, 5, 1/3). i4 I GUESS is 1/3, but I don't think that is right. Power of the 1 ohm resistor is 25, and 1/3 for the 3 ohm resistor.
So apparently, I've screwed up. Help?
Check your work on the KCL: A + (A-4)/3 = 8. A=5 doesn't satisfy the equation.
Ah, I see. God, that was stupid. If I have more problems(probable), I'll post them on this thread.
Hey man! How did you find other problems? Can you give me solutions? please)
PM me. What problems are you having?
