Doppler Effect aturla frequency
The discussion focuses on the Doppler Effect, specifically comparing classical and relativistic shifts. Participants explore the equations for frequency observed when the source moves towards a stationary observer, emphasizing the conditions where the speeds of the source and observer are much less than the wave speed. They discuss the need for a deeper relationship between the speeds involved, rather than merely stating they are non-zero. Additionally, there is a request for guidance on expanding the relativistic Doppler shift formula using binomial expansion techniques. The conversation highlights the importance of understanding the mathematical relationships to accurately derive the differences between classical and relativistic effects.
stunner5000pt
In class we were explained that if the source moves toward the stationary observer
f' = f_{0} \frac{v}{v-v_{s}}
where f0 is then aturla frequency of the wave, v is hte speed of the wave, and vs is the speed of the source
and f' = f_{0} \frac{v_{rel}+v}{v}
where vrel is the speed of the observer
a)SHow that the result are thesame if the source and observer speed are much less than the wave speed
Now i can easilky say that v - v_{s} \neq 0 and similarly v_{rel} + v \neq 0 but is that really enough??
It is worth 5 marks in thsi assignment
b) FInd the difference between theclassical Doppler shift and the relativitistic Dopper shift up to the second order terms in (v/c)^2
now i know the relativistic expression is
f' = f_{0} \sqrt{\frac{1+\beta}{1-\beta}}
but how do i expand this. I do know how to expand \frac{1}{1-x}
but in this case i can get v / v-c and c/v-c how would that work??
From your question it seems like you are trying to pove:
f' = f_{0} \frac{v}{v-v_{s}} =f_{0} \frac{v_{rel}+v}{v}
\frac{1}{1-x} = 1 + x \ \ {When\ x\ll1}
so we have
f' = f_{0} \frac{v}{v-v_{s}} = f_{0} \frac{1}{1-\frac{v_{s}}{v}} \cong f_{0} ( 1 + \frac{v_{s}}{v} ) = f_{0} \frac{v_{rel}+v}{v} =f_{0} (\frac{v_{rel}}{v}+1)
Since v_{s} = v_{rel}
hmm I would use the binomial Expansion. I am lazy and did not want to write out the binomial Expansion so here is a link:
http://hyperphysics.phy-astr.gsu.edu/hbase/alg3.html
a)No...U should try to put the expressions in a way in which u can take the relevant limit v<<v_{s}
b)Use this trick:
\frac{1+\beta}{1-\beta}=1+\frac{2\beta}{1-\beta}=1+\frac{1}{something}
and now to take out terms in \beta^{2} outta the square root...
Daniel.
Wouldn't be enough for me! Saying they are not 0 doesn't say anything about the relationship of v- vs and vr- v. What is the relationship between vs and vr?
What is β? You should know how to expand \sqrt{1- x^2} in a power series. Once you have expanded it in a power series, replace β by its expression in v and c.
