Determinant of Matrix Involving trig Functions
The discussion focuses on finding the determinant of a matrix involving trigonometric functions. The matrix in question is composed of cosine and sine values at specific angles. Participants suggest using trigonometric identities and properties, such as the cosine of angle sums, to simplify the expressions. There is a mention of using rotation matrix properties, although no specific property is identified. The conversation highlights the importance of expanding expressions rather than solely simplifying them.
V0ODO0CH1LD
Find the determinant of the matrix {{cos 25°, sin° 65}, {sin 120°, cos 390°}} (sorry, can't latex). {cos 25°, sin° 65} is first row and {sin 120°, cos 390°} is the second one.
cos(a + b) = (cos a)(cos b) - (sin a) (sin b)
I know you can just plug the values in a calculator, but apparently you can solve it by using some trig identities. I also though about using some property of rotation matrices but couldn't find any that fit the problem. Anyway, this is as far as I got:
cos (a + b) = (cos 25°)(cos 390°) - (sin 65°) (sin 120°)
Convert sin(65) into cos(something), rewrite sin(120) as sin(90+30), you can still do one more thing, cos(360+x)=cos(x). Can you start from here?
Yeah, thanks! I was so caught up thinking on how to simplify the expression I forgot I could just keep on expanding it!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
