Deriving SHM: Help Needed for Challenging Problem in Textbook
  • Thread starter Thread starter tonykoh1116
    Derivation Shm
The discussion revolves around deriving the harmonic oscillator differential equation for a mass-spring system with friction. The problem involves a block attached to a spring, moving on a board with static and kinetic friction as it slides back and forth. The key challenge is calculating the total force acting on the block as a function of its position, particularly when it moves to the left while experiencing friction. Participants are encouraged to focus on the forces involved and how they relate to the block's motion. Assistance is sought to navigate the complexities of the derivation.
tonykoh1116
This is actually the problem in the textbook.
I'm trying to derive the harmonic oscillator differential equation for this system, but It seems like it's very very challenging.
could anyone help me out?
Following is the question and figure from the textbook.
A block of mass m is attached to a fixed support by a horizontal spring with force constant k and negligible mass. The block sits on a long horizontal board, with which it has coefficient of static friction μs and a smaller coefficient of kinetic friction μk. The board moves to the right at constant speed v. Assume the block spends most of its time sticking to the board and moving to the right, so the speed v is small in comparison to the average speed the blok has as it slips back toward the left.
Derive the harmonic oscillator differential equation for the system.
F=ma
F(sp)=-kx
E=K+U
I couldn't figure out.
( The figure has a copyright from the textbook).
I will delete this post if it could cause the copyright problem.
Your differential equation is relevant when the block moves to the left. It is sliding (with friction) and accelerated by the spring. Can you calculate the total force which acts on the block as function of its position?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
