Effect of a Lindlar catalyst on an alkene?
  • Thread starter Thread starter rblake92
    Alkene Catalyst
Lindlar's catalyst facilitates the syn addition of hydrogen to alkynes, stopping at the alkene stage. When applied to a molecule containing both an alkyne and an alkene, the alkene remains unaffected due to the catalyst's selective activity. The catalyst is specifically poisoned to prevent further reduction of double bonds, ensuring that the alkene does not convert to an alkane. This characteristic makes Lindlar's catalyst useful for selectively hydrogenating alkynes without altering existing alkenes in the same molecule.
rblake92
I know a Lindlar catalyst will cause syn addition of hydrogens to an alkyne and then stop at an alkene, but what about a molecule that has both an alkyne and an alkene in it to start. Is the alkene taken to an alkane or is it simply not affected? Thanks for your answers.
Chemistry news on Phys.org
Lindlar's catalyst is poisoned so that it do not reduce the double bonds furthur into single bond.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
