How to design an XOR with these gates?
  • Thread starter Thread starter jean28
    Design
Designing an XOR gate using 2 NAND gates, 1 NOR gate, and 3 inverters is feasible. The XOR function can be expressed as (A OR B) AND ~(A AND B). By utilizing the properties of NOR and NAND gates, the required gates can be arranged to achieve the XOR output. The key is to correctly apply the logic of negation and combination of the gates. This method effectively utilizes the specified gates to construct the desired XOR functionality.
jean28
I need to design an XOR with 2 NANDS, 1 NOR, and 3 inverters. Is it possible? I can't seem to find how to do it now.
Consider that the XOR of A and B can be written as:
And recall that NOR is ~(OR) and that NAND is ~(AND) (NOT OR and NOT AND)
And that ~(~(A)) is just A
Then you can use up that exact quantity and type of gate!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
87K
