An experiment with air pressure.
Blocking airflow to a heated fan with a piece of paper caused it to shut off due to overheating. The fan has a thermal switch that protects it from damage by cutting power when temperatures rise too high. After removing the obstruction, the fan remained off for about five minutes as the thermal switch needed time to cool down and reset. This phenomenon is similar to hair dryers, which also require adequate airflow to prevent overheating. Proper airflow is essential for the fan's operation and longevity.
jaydnul
Im at work and i have a heated fan by my side. I decided to do a small experiment with air pressure. I placed a piece of paper at the back of the fan to block in coming air and the whole fan shut off and wouldn't come back on for 5 minutes. What happened inside the fan that made it turn off? If it was a circuit breaker, wouldn't it just turn back on immediately after i removed the paper?
The reduced air flow caused the fan to over heat, and it has a thermal switch to protect it. It then takes some time for the switch to cool down and reset. Same think happens with hair dryers - we used them dry boots, and you had to fan a way that alloed enough air flow to prevent a shut off.
The heat has to be dissipated in order to keep everything working within the fan. So if you place the paper behind, it reduces the flow of air thus causing fan to over heat. So, you need some time for it to cool and to reset.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
