Powers of a Matrix and Eigenvalues proof
muzziMsyed21
Prove that if A is an nxn matrix with eigenvector v, then v is an eigenvector for Ak where kε(all positive integers)
Av=λv
Av=λv
A(Av)=A(λv)
Akv=λ(Av)
i know i may not be doing it right but this is what i can think of so far
muzziMsyed21 said:
Av=λv
A(Av)=A(λv)
What if I rewrote that as
A(Av) = λ(Av)
If you want to show that v is an eigenvector of a power of A (given that v is an eigenvector of A itself), you need to know what happens when you multiply v by some power of A. Consider the second power to begin with - the pattern you see continues for higher powers. So,
if Av = λv, what do you get when you examine
A(Av) = A(λv)
* and simplify the left side?
* and simplify the right side (remember that A(λv) = λ(Av)) when you simplify the right?
If you correctly simplify these two pieces you should be able to show that v IS an eigenvector of A-squared, AND you will know the associated eigenvalue. The latter is important, because it will give you a major hint about the link between A^k, v, and the corresponding eigenvalue. Once you see that link, you will know how to answer your question.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
