Finding the resultant of two vectors
  • Thread starter Thread starter eddiedowen
    Resultant Vectors
To find the resultant of vectors S and T, first resolve each vector into its rectangular components using trigonometric functions. Vector S has a magnitude of 24.3 units at an angle of 54.8 degrees below the negative x-axis, while vector T has a magnitude of 18.8 units at 37.7 degrees above the positive x-axis. The components can be calculated using sine and cosine for each vector. To determine unknown angles in the right triangles formed, remember that complementary angles sum to 90 degrees. Completing the problem template is necessary for further assistance.
eddiedowen
S is a vector 24.3 units in magnitude and points at an angle of 54.8 degrees below the negative x-axis. T is a vector 18.8 units in magnitude and points at an angle of 37.7 degrees above the positive x axis. Find the resultant of the two vectors by resolving into rectangular components.
Sketch right triangles involving S and T and use cosine and sine to find each vector's x and y components. Then add the components.
How do I know what the other angles are aside from 90 degrees?
You can use the tangent to find them, since you know the length of the adjacent and opposite sides.
The problem statement gives one of the angles of each triangle. Did you remember that the complementary angles of a right triangle sum to 90 degrees?
Eddie, you need to complete the template before we can help you.
