Calculating Spring Constant and Mechanical Energy
The spring constant is calculated using the formula F=kx, resulting in a value of 122.5 N/m when a 0.5 kg mass stretches the spring by 4 cm. The mechanical energy of the mass, when displaced 2 cm from its equilibrium position, is determined to be 0.025 J using the work formula W= 0.5kx². The speed of the mass as it passes through the equilibrium position is calculated to be 0.32 m/s using the kinetic energy formula KE= 0.5mv². Clarification is sought regarding the correct application of displacement values in the formulas. The discussion emphasizes the importance of understanding when to use the initial stretch versus the displacement from equilibrium.
xCharade
When a .5kg mass is suspended from a spring, the spring stretches 4cm. The mass is then displaced 2cm from its equilibrium position and released.
(a) What is the spring constant? (b) What is the mechanical energy of the mass? (c) What is the speed of the mass as it passes through its equilibrium position going down and going up?
F=kx (k is spring constant)
W= .5(k)x2
KE= .5mv2
For part A I used F=kx:
mg=kx
(.5kg)(9.8m/s2) = k (.04m)
k= 122.5N/m
For part B I used W= .5kx2:
W= .5(122.5N/m)(.02m)2
W= .025J
For part C I used KE = .5mv2
.025J = .5(.5kg)v2
v= .32m/s
I just need to make sure that I'm on the right track with this problem. I can get confused as to when to use .04m and .02 and generally with using formulas.
How much gravitational energy is there when the mass is displaced 2cm = 0.002m from its equilibrium position? Hint: The spring originally stretched 0.0004m when the mass was suspended.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
