Capacitance (why are the charges no the same?)
In the discussed circuit, capacitor C1 is charged and then connected to uncharged capacitor C2 after switch S1 is opened. The key point is that when S2 is closed, the two capacitors are in parallel, resulting in the same voltage across both capacitors. This means that while the voltage remains equal, the charge on each capacitor can differ, as the total charge is conserved and equals the initial charge on C1. In contrast, when capacitors are connected in series, the charge remains the same across them, leading to different voltages. Understanding these principles clarifies the behavior of capacitors in different configurations.
360705474
Consider the circuit shown in the attachment. Capacitor C1 is first charged by closing switch S1. Switch S1 is then opened, and the charged capacitor is connected to the uncharged capacitor by closing S2. Calculate the initial charge acquired by C1 and the final charge on each capacitor.
C1= 6.00 μF
C2= 3.00 μF
V=20.0 V
This is a question from College physics book on Capacitance. I managed to solve the first subquestion. To find the final charge on each capacitor, I used Q is the same for both the capacitors after S2 is closed and S1 is open. However, the sample answer suggested that Q is different while the voltage across the capacitors are the same. I am very confused here. Because the circuit is not a close circuit (as S1 is open), I assume this situation is the same as you connect these 2 capacitors in series? Then isn't it that the charge should be the same? If not, I will be very thankful if you could help me explain it! Thank you :)
Welcome to PF,
Actually the situation is that the two capacitors are in parallel. As a result, the voltage across them must be the same. If you think about it, suppose if the voltage across them weren't the same: then the electric fields across them would be different. This would be an unbalanced situation with a net electric field: charge would be transferred from the plates of one capacitor to the other until this net field disappeared (and the voltages were hence equal).
Yes the voltage must be the same - apply KVL around the right hand loop when S1 made.
The total charge eg sum of charge on both capacitors at the end, will equal the charge originally on C1.
cepheid said:
Welcome to PF,
But why the voltage is different when the capacitors are connected in series? Won't the charges move then?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
