How to calculate a trapeze/ pendulum's arc distance
  • Thread starter Thread starter katkinson
    Arc
To calculate a trapeze's arc distance on the moon, understanding the forces at play is crucial, particularly the relationship between tension, gravitational force, and centripetal force. When the pendulum reaches its peak, the centripetal force equals zero, indicating the object is momentarily at rest and all energy is potential. The tension in the system can be expressed as Ft = mg sin(theta), which is essential for determining the angle and subsequently the arc length. The amplitude of the swing is influenced by the initial speed of the pendulum at its lowest point, as well as conservation of energy principles. Ultimately, the length of the swing can be calculated using the formula T=2π√(L/g) in conjunction with the pendulum's initial conditions.
katkinson
This is an update to an earlier post. Since then, I now understand that a pendulum stops when its tension force= mg sin(theta)--because then centripetal force will=0, so velocity will be 0. However, now I am trying to determine how a trapeze would work on the moon.
KE=1/2 mv^2
PE= mgh
T=2π√(L/g)
Fc=mv^2/r
Ft=Fc-mg sin(theta)
KE (initial) + PE (initial) = KE (final) + PE (final)
Drawing a free body diagram, I determined that when an object peaks during its swing the following is true: Because the object is stopped, Fc=0. Because Fc=0 and the radius and mass are supposedly constant, velocity must=0. (That also means that it is 100% PE). Because Ft - mg sin (theta) = 0, then Ft= mg sin (theta). I am trying to determine what sin (theta) is, because then I can determine the length of the swing on the moon. However, I do not know how to determine Ft so I thought I would try using the other method while using T=2π√(L/g). However, I do not know how I can use the time to determine the length of the arc
Thanks so much
The amplitude (length of swing) depends on how fast the pendulum was pushed to begin with, i.e., its speed when it is at the lowest point. That, and conservation of energy, result in a particular amplitude.
Likes 1 person
