Measuring sum of two components of spin angular momentum
FarticleFysics
What are the possible results of the measurement of the sum of the x and z components of the spin angular momentum of a spin-1/2 particle?
Sx = Spin angular momentum operator x
Sz = Spin angular momentum operator x
I started by applying the spin-up eigenket to the sum of the spin angular momentum operators.
(Sx + Sz) | up > = Sx | up > + Sz | up > = -1/2h_bar + 1/2h_bar = 0
The text I'm using proves that Sx | up > = 1/2h_bar | down >
and like wise Sx | down > = 1/2h_bar | up >
Does this mean if you were to probe the particle for spin up in the x direction you would actually see spin down?
then I applied the spin down eigen-ket to pull the possible eigenvalues from the operators.
(Sx + Sz) | down > = Sx | down > + Sz | down > = +1/2h_bar + (-1/2h_bar) = 0
I feel that there is something wrong with how I've gone about calculating this.. I know that Sx and Sz don't commute therefore you cannot measure their eigenvalues simultaneously. Since I get zero did I show this correctly?
Also, the eigenkets for spin up and spin down are considered the eigenvectors, correct?
I am still trying to get the hang of the linear algebra and what everything means so any help would be amazing!
Thanks
One problem with your work is that saying, for example, that ##\hat{S}_x \lvert \text{up} \rangle = \frac{\hbar}{2}## doesn't make sense. This is akin to writing
$$\frac{\hbar}{2}\begin{pmatrix} 0 & 1 \\ 1 & 0 \end{pmatrix}\begin{pmatrix} 1 \\ 0 \end{pmatrix} = \frac{\hbar}{2}.$$ The lefthand side is a vector, but the righthand side is a scalar.
No. Rid yourself of the notion that taking a measurement means applying the associated operator to a state.
The result of a measurement is one of the eigenvalues of the associated observable. Given the state of a particle, you can calculate the probability amplitude for a particular result by finding the projection of this state in the direction of the corresponding eigenstate. For example, if you were measuring the spin in the z-direction, you would need to know the eigenvalues of ##\hat{S}_z##, which are ##\pm \hbar/2##, and the corresponding eigenstates, ##\lvert + \rangle## and ##\lvert - \rangle##. If the particle is in state ##\psi##, the probability amplitude for finding the particle in the spin-up state is ##\langle + \vert \psi \rangle##, which is generally a complex number. The probability is given by square of the modulus of the amplitude.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
