Understanding the math of inductance
  • Thread starter Thread starter Jayen
    Inductance
The discussion focuses on the concept of inductance and the relevant formulas for calculating induced electromotive force (emf) in coils. Faraday's law is highlighted, emphasizing the relationship between the number of turns in a coil, magnetic flux, and the rate of change of that flux. Participants clarify the distinction between magnetic flux and flux density, noting the importance of integrating flux density over an area to obtain flux. The impact of core permeability and frequency on the equations is also discussed, with an emphasis on how these factors influence the induced voltage. The conversation concludes with a participant seeking clarification on calculations related to a solenoid, indicating the complexity of applying these principles accurately.
Jayen
Hello all,
I do apologize if this is in the wrong section as this is my first post. If I have posted in the wrong area please let me know.
I have a basic understanding of the concept of inductance but have read many formulas which I think are trying to express the same idea but from various sources. I would like to put my understanding forward and have it corrected where need be.
Faraday law determines the amount of emf (Voltage) which will be induced by a coil of wire into an electromagnetic field.
emf (voltage induced) = -N Δ\Phi / Δt
where N = number of turns in the coil
\Phi = Flux density (BA) measured in Teslas
B = I think this depends on the type of coil, for a solenoid B = Mo n I
where Mo = 4pi x 10-7
n = number of turns in coil / length of the coil
I = current
A = Cross sectional area of the coil (pi r2)
t = time
There are a few variables I would think may be a factor in this equation which are not included. Firstly the permeability of the core and secondly the frequency at which the magnetic field changes.
Any help in understand these equations would be greatly appreciated.
Thankyou.
ΔΦ / Δt term also take frequency into account. More the frequency, more will be the value of ΔΦ / Δt. Flux is due to magnetic motive force which is a function of current. Suppose current is i=cos(2*pi*f*t), taking rate of change of this current will move 2*pi*f outside and voltage will have a direct relation with frequency.
Jayen said:
Hello all,
I = current
t = time
\Phi is flux not flux density. Once you integrate B (flux density) over and area you get flux (\Phi). It may not seem like much of a distinction but it's important. Flux density is a vector field with magnitude and direction (like the flow of water currents). Flux is a scalar value (like the total amount of water flow through the mouth of a bay).
For a solenoid, B = \mu NI/l
In general, B = \mu H (Sometimes you have to account for the magnetization of the material so this one is not always true)
So the magnetic field strength is, H = NI/l
And flux density is, B = \mu_0 \mu_r H
Where \mu_r is the relative permeability of the material and \mu = \mu_0 \mu_r
Thanks very much for your replies. I think this has clear things up for me but just to make sure I am 100% clear in my head I want to see if I am correct (this is not homework).
If I have a solenoid of 10 cm total length, 100 turns, iron core (200 μ) and radius of 4cm with 1500W @ 1500V 120Hz AC. Would the following be correct?
emf = -100 ΔΦ / Δt
B = 200 x 100 x 100 / 0.1 (200 000 T)
A = 0.00503m2
Φ = 1006 Tm2
emf = -12 120 481
I have also seen B = μN2A/l and I would assume this relates to a solenoid. Could someone please elaborate how the two differ.
Your result is 12 million volts for a little solenoid?
Current is a function of time in AC. Your result should be a function of time too.
Have you studied Calculus? Do you know how to take a derivative?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
