Short circuit current distribution
Adding a wire to create a short circuit can still result in a small current flowing through the load due to the resistance of the wires. The current distribution is influenced by the series load, with the total current shared between the short circuit and the remaining load based on their resistances. A perfect short circuit does not exist in practice, as there will always be a voltage difference across the short. This voltage difference leads to residual current flowing through the original load path, which has higher resistance. Understanding these dynamics is crucial for accurate circuit analysis.
Physicist3
Hi, After adding a wire across a circuit to section off part of the load in the form of a short circuit, I am still seeing a couple of milliamps flowing through the load. Is this due to the fact that the wires used to create the short circuit will have a small amount of resistance, hence preventing all the currrent flowing through the short circuit?
Yes.
The remaining series load will determine the current. The current will be shared by the short and the shorted part of the load in proportion to the reciprocal of their respective resistances.
In reality there is no such thing as a perfect short circuit. There will be a voltage difference across the short. That will result in a residual current through the higher resistance original load path.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
