How Does Quantum Tunneling Affect Electron Reflection Probability?
PsychonautQQ
Calculate the reflection probability for a 5 eV electron encountering a step in which the potential drops by 2 eV
To answer this question, wouldn't I need to know where E > U or U > E? Also wouldn't I need to know the width of the potential barrier it's trying to penetrate?
The way I understand the question is as follows:
Take the potential function
V(x) = \left\{
\begin{array}{ll}
0 & x \le 0 \\
- 2\text{ eV} & x > 0
\end{array}
\right.
and consider an electron coming in from ##x = -\infty## with an energy of 5 eV.
From what you say,I see that you haven't understood the question,and so you can't get the answer.
An important point that seems you don't know,is that only potential energy difference has physical significance.So you can choose where the potential is zero arbitrarily and so a constant potential can always be called zero.The problem is saying that an electron is moving in a constant potential till it reaches a potential drop.So we can call the potential before the potential drop to be zero and negative after that.Also because no other change in potential is stated,we can assume that the potential is constant till it drops somewhere and then stays constant again and so there is no width.Also its not a potential barrier,you can call it a potential canyon,starting at the point of drop and continuing till infinity.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
