Intersection of TWO QUADRICS/Conics
  • Thread starter Thread starter glueball8
    Intersection
glueball8
Find all the plane (x,y) all points of intersection of two quadric:
2x^2-xy+3y^2=36,
3x^2-4xy+5y^2=36
I want to know the general process to solve something like this. Is the problem solved by using det somehow? Or divide by y^2 and let k=x/y then make 2 equations are solve that somehow??
OK, so eq 2-eq1, then use that as eq 3. Solve eq1 and eq3 as a system, which got that answer. Is this process correct?
My class is a ring&field class. I don't see how this even related at all... No determinate needed to solve this?
hi glueball8! :smile:
(try using the X2 button just above the Reply box :wink:)
yes, that will give you two values for x/y, which you can then substitute into the original equations :wink:
(and if they weren't both 36 on the RHS, of course you would multiply one of them to make the RHSs the same)
(try using the X2 button just above the Reply box :wink:)yes, that will give you two values for x/y, which you can then substitute into the original equations :wink:
Thanks, do you know what does this have to do with ring&fields (Abstract algebra)? I thought you had to use something special to solve it but apparently its just regular system of equations.
i've no idea :redface:
anyone? :smile:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
