Constant Acceleration; answer not correct for some reason?
A motorist experiences a collision after applying brakes with a negative acceleration of 6.1 m/s², while the car was estimated to be traveling at 22 km/h during the collision. The skid marks measured 35 meters long, leading to calculations for the initial speed and time elapsed from braking to collision. The initial speed was calculated as 19.7 m/s, but there was confusion regarding the direction of acceleration and the correct application of signs in the equations. It was suggested to reassess the direction of displacement and acceleration to ensure accurate calculations. Clarifying these aspects is crucial for solving the problem correctly.
dudenamedscott
A motorist suddenly notices a stalled car and slams on the brakes, negatively accelerating at 6.1m/s2 . Unfortunately this isn't enough, and a collision ensues. From the damage sustained, police estimate that the car was going 22km/h at the time of the collision. They also measure skid marks 35m long. A:How fast was the motorist going when the brakes were first applied? B: How much time elapsed from the initial braking to the collision?
2 a (x - xo)= v2 - vo2
v(average)=d/t
A: 2(6.1m/s^2)(35-0m)=(55/9m/s)^2-vo^2
vo^2=19.7m/s
B: 19.7m/s=35/t
t=1.78sec
I may just be totally off, but I feel like I understood the problem. Masteringphysics doesn't agree. Thanks again haha.
you mean v = 19.7 m/s ? ... are acceleration and displacement in the same direction?
what happened to the minus sign in front of vo^2 ?
v(average)=d/t
vo^2=19.7m/s
B: 19.7m/s=35/t
t=1.78sec
If you take the displacement as positive, say to the right, in which direction is the acceleration? (Check your signage). Then once you get the correct value for the initial speed, you need to calculate the average speed to find the time in part b.
