Conserving Heat & Steam at Refineries: Ideas & Solutions
  • Thread starter Thread starter turtlesoup2
    Heat Ideas Steam
Conserving heat and steam at refineries can be approached by using dry coolers instead of traditional cooling towers, which allows for water vapor recovery but comes with higher costs and energy requirements. The energy from cooling tower water is typically low grade and not suitable for generating plant steam, as it is much cooler than the required temperatures for steam production. A heat pump can be an effective alternative, providing simultaneous heating and cooling, though it may also involve significant upfront investment. The discussion highlights the importance of understanding thermodynamics in evaluating these solutions. Overall, exploring innovative methods for heat recovery can enhance efficiency in refinery operations.
turtlesoup2
after visiting my fathers job and noticing the tons of cooling towers, i wanted to know if there was a way to prevent/ conserve the lost steam and heat. At the refinery the cooling towers are used to cool water from multiple applications from varying temperatures. A water pump could replace a cooling tower and create steam that could be used else where in the plant(though steam is already generated on site, but this approach would be simpler).The only issues besides a large upfront cost and maintance is the loss of cooling water which may or may not be reused in the refining process (though I'm told by my father is isnt) I'm just kinda brainstorming and would love to hear thoughts and ideas
Likes heattransferequipmen
Welcome to PF!
The basic answer is "yes", but you have a few misconceptions about plant thermodynamics:
1. Yes, you can save the water vapor. The most common way to do this is with a dry cooler: http://www.colmaccoil.com/drycoolers/
It's just a heat exchanger that you circulate the water through - like a car radiator. It uses less water, but more energy than a cooling tower and is more expensive. So it is a tradeoff.
2. An engineer wouldn't typically call that "steam" since it is just water vapor mixed with air, that you see because it is condensing out of the air. Steam is water vapor that is not in air and is therefore much hotter. This matters because the energy in cooling tower water is very low grade, meaning it isn't much warmer than ambient air, which makes it not very useful to recover unless you have a specific need for such low grade heat (such as simultaneous heating and cooling of water or air). You definitely couldn't use it to generate plant steam. The lowest typical grade of plant steam is 15 psi/250F whereas the water vapor coming out of a tower is a small fraction of atmospheric pressure and at most 85F.
3. I'm not sure what you have in mind with a water pump, but a pump is of course already used to circulate the water through the cooling tower. And pumps don't create steam. Not sure what you were getting at there.
Sorry about the confusion, I was trying to refer to a heat pump instead of a water pump
No sorry needed: a heat pump is a definite possibility and often used in heating/air conditioning systems that require simultaneous heating and cooling.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
11K
