Does Gate Oxide Breakdown Voltage Vary with Bias Polarity in NMOS Transistors?
  • Thread starter Thread starter t2000_wong
    Gate Voltage
Gate oxide breakdown voltage in NMOS transistors is influenced by bias polarity, with significant differences observed between positive and negative gate biases. Research indicates that time-dependent dielectric breakdown lifetimes are approximately ten times longer under positive bias conditions. Conversely, negative bias leads to faster tunneling effects in the gate oxide. This polarity dependence is critical for understanding the reliability and performance of NMOS devices. Overall, bias polarity plays a crucial role in gate oxide wearout characteristics.
t2000_wong
For a NMOS transistor, is there a difference in gate oxide breakdown voltage if we apply a positive bias on gate and a negative bias on gate? (assume S/D/bulk are ground)
According to the paper
Hokari, Y, "Stress voltage polarity dependence of thermally grown thin gate oxide wearout" IEEE Transactions on Electron Devices, vol. 35, no 8, August 1998
there is a difference. In fact time-dependent dielectric breakdown lifetimes is one order-of-magnitude longer for positive biases and you get tunneling quicker with negative stress.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
