Actual rankine cycle - Work done by pump
In an actual Rankine cycle, the work done by the pump can typically be neglected unless a high degree of accuracy is required for specific analyses. The work term associated with the pump is often insignificant when compared to the heat added by the boiler and the work output from the turbine. This is primarily because the pump is moving liquid condensate, which requires much less energy than compressing a gas or vapor. Therefore, in most practical scenarios, the pump's work does not significantly impact the overall thermal efficiency calculation. Neglecting the pump work simplifies the analysis without substantial loss of accuracy.
Jameseyboy
Hi,
In what cases do I neglect the work done by the pump in an actual rankine cycle?
I am reading that h5-h4 is negligible but in what circumstances do I accept this.
Is this only for ideal rankine cycles?
As I understand thermal efficiency is (work out + work in)/Heat in
Thanks
Unless you are doing a very specific analysis which requires a good degree of accuracy, you can almost always neglect the work done by the pump. If you are unsure why, I'd recommend that you calculate the work term and compare it to the heat added and rejected by the boiler and condenser, respectively, and the work out from the turbine. You will see notice that the work done by the pump is very insignificant compared to the other processes. The reason the work done by the pump is so small is because it is pumping liquid condensate as opposed to a gas (or vapour) which would require a compressor and a much larger energy input.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
