High-School Physics Practical Investigation- Need Help
A high school student from Australia is seeking help for a practical investigation on photonics and light transmission for their VCE studies. They propose testing the effect of optical densities, color filters, or lenses on a laser transmitting an audio signal. Suggestions include investigating everyday obstacles like fog, rain, and smoke to assess their impact on signal transmission. The student is looking for feedback on their ideas and any new suggestions for their project. Engaging with these concepts will enhance their understanding of light and signal interference.
OnceIWasBooker
Hey Guys,
I'm a high-school student from Australia, and I am an avid lover of physics! I'm top of my class, however I am not a physicist so please explain things at a level I would understand. I am also new to the forum so i apologize in advance for any mistakes.
As part of my VCE studies, I must conduct a practical investigation and write a report on an area of photonics and light transmission of a signal with 2 variables. The challenge I am having is coming up with something to test. My ideas thus far are:
1. Use a laser to transmit an audio signal across a certain distance to a receiver, and recording the effect that different optical densities in the path of the light would do eg. place plexiglass/lexan/water of varying thickness in front of the laser to see what changes are made to the signal. I would be able to control background light, distance etc.
Or...
2. Use a laser to transmit an audio signal across a certain distance to a receiver, and placing colour filters in the path of the laser and record the effect.
Or...
3. Use a laser to transmit an audio signal across a certain distance to a receiver and place a lens (concave, convex) and record the effect.
Please let me know if my ideas are worth investigating, and any improvements/ new ideas are welcome!
Cheers,
Booker
How about running the signal through everyday problems:
simulated fog, rain, smoke, and parked cars ... these all can interfere with the signals.
You can then determine how much "interference generation" can be tolerated by the system.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
