Maximum temperature of fuel air cycle
In a stoichiometrically correct air-fuel mixture, some air remains unburned after combustion, contrary to theoretical expectations of complete combustion by point 3 on the P-V diagram. This incomplete combustion occurs due to practical challenges in achieving full combustion across varying RPMs. To enhance performance, mixtures are often made air-rich, allowing more fuel to burn while still leaving some air unburned. The flame front's behavior is affected by the combustion cavity's shape, leading to inefficiencies, especially near cylinder walls. Addressing these thermodynamic inefficiencies presents significant opportunities for advancements in engine design.
pnkj115
When Stiochiometrically correct mixture(equivalence ratio=1) is burned in air fuel cycle some of the air is still left after point 3 in P-V diagram...Theoretically the whole fuel and air should combust till point 3..Then why is some air left out there.And thus the max temp is when mixture is 6% richer.Wh is this so??. Please help me
That is the theory. In practice the fuel air mixture does not burn completely and it would be quite a bother to make it combust to full completion in the whole RPM range. It is easier to make the mixture air rich for better performance, thus more fuel is burned and some air is still left.
The main problem is with the flame front that would prefer a spherical combustion cavity, yet that is not practical, and thus at the cylinder edges the flame does not perform too well.
There are linear spark plugs that start the flame front in a line and get a more or less cylindrical flame front, but they have issues too. The Flame front performs differently in the middle that next to the walls of the cavity, as you have surface effects, thermal cooling and reflection of thermal radiation and not to forget different air/fuel mixtures.
If you can design a solution for thermodynamic inefficiencies in a combustion engine, you have a bright future in the engine business.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
22K
16K
