Chemistry of Water: Boiling Time Comparisons
  • Thread starter Thread starter yeshli2nuts
    Chemistry Water
The discussion centers on the comparison of boiling times for different solutions: pure water, water with dissolved salt, and water with dissolved sugar. It highlights that the presence of a solute, such as salt or sugar, raises the boiling point of water due to stronger interactions between the solute and solvent molecules. This phenomenon is explained by the concept of boiling point elevation, where dissolved substances create a more complex structure that hinders the escape of water molecules into vapor. The stronger interactions in salt solutions compared to sugar solutions are noted, suggesting that salt will have a more significant impact on boiling time. The conversation encourages understanding the underlying chemical principles, including the van't Hoff factor and the arrangement of water molecules around solutes.
yeshli2nuts
i had this problem for homework and i need some help. if i had 1 cup of water compared to 1 cup of water with tablespoon of salt disolved in it, which would take longer, by how much time, and why to bring to a boil? and how about 1 cup of water with a tablespoon of sugar compared to the other two?
thanks a lot. :smile: :smile: :biggrin: :-p
Chemistry news on Phys.org
You need to have your thoughts first instead of expecting us to do your homework for you. What concept does this question relate to?
Any solvent with dissolved substance boils higher and freezes lower then the pure one.
G
Try thinking about what needs to happen for liquid molecules to escape the liquid state and be vaporized into gas. Now, what happens if something is dissolved in it? Try writing out the chemical equation for the dissolution of a salt. Namely, how does the solute affect the new solvent compared to the pure solvent?
Because the solute(salt)-solvent(liquid molecule like water) interactions are stronger than liquid intermolecular interactions, some cluster-like structures form in the solution. The stronger trap of the liquid molecule prevent its escape, and leads to the rise of boiling point. Generally, viscosity of very dilute solution increases with concentration of salt. but at medium and higher concentration ranges, the relation is not so simple.
additional hint: van't hoff factor and perhaps consider the much more ordered arrangement of water in solvating the salt in comparison to the sugar.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
