Proof of expected value expression
The discussion focuses on deriving an alternative expression for the expected value of a non-negative discrete random variable X. The standard formula for expected value is E[X] = (sum) x*p(x). The user seeks guidance on proving that E[X] can also be expressed as E[X] = (sum: i from 1 to infinity) P(X>=i). A suggested approach involves using the relationship P(X>=i) = (sum(j=i,inf) P(X=j)) and interchanging the summation indices to simplify the expression. This method ultimately leads to the desired proof of the expected value expression.
grimster
The usual expression of the expected value of X is:
E[X] = (sum) x*p(x)
i'm supposed to show that, for X a random non-negative discrete random(stochastic) variable, we have that:
E[X]=(sum: i from 1 to infinity) P(X>=i)
i have absolutely no idea how to do this. does anyone want to push me in the right direction?
P(X>=i)=sum(j=i,inf) P(X=j). Plug this into your sum over i, interchange i and j and you will get what you want, since the sum over i will simply be j.
