Help With Forces: Find Friction Coefficient
  • Thread starter Thread starter Confuzzlement
    Forces
To find the coefficient of friction between the sled and the sidewalk, use the formula for frictional force (Ff), which is the product of the coefficient of friction (μ) and the normal force (Fn). In this case, the sled is being pulled at a constant speed, indicating that the applied force (Fa) equals the frictional force (Ff). Given that the applied force is 18N and the weight of the sled (which equals the normal force on a horizontal surface) is 52N, the equation can be set up as Ff = μ * Fn. Rearranging this gives μ = Ff / Fn, leading to μ = 18N / 52N, which simplifies to approximately 0.346. Understanding these relationships is essential for solving the problem effectively.
Confuzzlement
I missed one day of school and fell behind entirely.
I understand that W=mass x gravity. That's basicly it.
In the problem..
A horizontal force of 18N is necessary to pull a 52 N sled across a cement sidewalk at a constant speed. What is the coefficient of the sliding friction between the sidewalk and the metal runners of the sled.
W=52...Fapplied is 18.
How do I find the coefficient of friction?
Fn
____________
Ff <--- |....| ---> Fa
v
Fw​
Do you know how Fn and the coefficient of friction are connected to Ff?
Do you know how Fa relates to Ff. With both of those pieces of information you should be able to solve the problem.
Fn
____________
v
Fw​
Formulas can be found here: http://scienceworld.wolfram.com/physics/Friction.html
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
