Average G-Force Calculation for Abrupt Deceleration from 30mph in 1m Distance
  • Thread starter Thread starter bond535
    Kinematic
To calculate the average g-force experienced during abrupt deceleration from 30 mph to rest over 1 meter, the equations of motion are applied. The initial velocity (Vo) is 30 mph, which converts to approximately 13.41 m/s. Using the equation V^2 = Vo^2 + 2aΔS, where the final velocity (V) is 0 and ΔS is 1 m, the calculated acceleration (a) is -90.7 m/s². This acceleration corresponds to approximately -9.25 g's, indicating the average g-force experienced during the deceleration. The discussion highlights the importance of unit conversion and proper application of kinematic equations in solving the problem.
bond535
Determine the average number of g's experienced by someone abruptly coming to rest from an initial velocity of 30mph (such as in a car crash). Take the distance involved in coming to rest to be 1 m.
V=Vo+at
ΔS=VoT+1/2at^2
V^2=Vo^2+2aΔS
t=?
a=?
Vo= 30 mph
V=?
ΔS=?
Thank you, I'm really stuck and any help will be deeply appreciate it.
You know Vfinal = 0 and ΔS (change in distance) = 1m. does that help?
so...
t=?
a=?
Vo= 30 mph
V=0
ΔS=1m
V^2=Vo^2+2aΔS
0=(30mph)^2+2a(1m)
which resulted in a= -450mph
I know g= 9.8m/s ... so I'm assuming I have to change the -450mph to m/s by diving -450/3600s = 0.125m/s
I really don't know what to do next or if I'm in the right track...
V^2=Vo^2+2aΔS
0=(30mph)^2+2a(1m)
a should be in units of m/s2
(convert mph to m/s)
