Understanding Voltage and Current Relationships in Inductors and Capacitors
  • Thread starter Thread starter leright
    Ice
Voltage leads current in inductors and current leads voltage in capacitors due to their mathematical relationships expressed in phasor notation. For inductors, the equation V = j(ω)LI indicates that the voltage is ahead of the current by 90 degrees, as differentiating the current phasor results in a phase shift. Conversely, for capacitors, I = j(ω)CV shows that the current leads the voltage by 90 degrees. This phase relationship can be visualized as a counterclockwise rotation on the phasor diagram, where multiplication by j corresponds to a 90-degree shift. Understanding these relationships through differential equations reinforces the concept that current lags voltage in inductors and voltage lags current in capacitors.
leright
This is probably a stupid question, and I realized the answer before, and I know my professor explained this in class, but why does voltage lead current for inductors and current lead voltage for capacitors. I don't want a physical explanation but a mathematical one. I am looking at my circuits notes and my professor states that it is obvious from the following equations that this is true.
V = j(omega)LI and I = j(omega)CV, where omega is frequency and I and V are the current and voltage phasors.
I know this is stupid because I was able to answer this question myself fairly easily just by looking at the equations, but now I look at them again and cannot answer this question for the life of me. SOMEONE HELP ME! :(
If I can't figure this out on my own then I will ask my professor tomorrow, but I'd rather not ask such a question since he states that it is obvious in his lecture notes.
Thanks a lot.edit: I suppose if you plug the phasors into the above equations and then convert them from exponential form to trigonometric form using euler's identity the sine expression becomes the real part (formerly the imaginary part) and then the cosine expression becomes the imaginary part (formerly the real part). Making the sine expression the real part would make the wave 90 degrees out of phase. Is this correct? I remember realizing the answer to this question before and my reasoning seemed much simpler.
Just write the differential equations for voltage and current in the two situations.
V = L di/dt
I = C dv/dt
And remember that when you differentiate a sine wave, you get the cosine function. So current lags the voltage in an inductor, and voltage lags the current in a capacitor. Make sense?
V = L di/dt
I = C dv/dt
yes, but I wanted to know why the above phasor relationships explain it, since my notes say that they do.
Do you know where the phasor notation comes from? For the inductor case, write the current i(t) = exp(jwt) and differentiate. So di(t)/dt = jwi(t). You can also think of a multiplication by j as a counterclockwise rotation by 90 degrees on the phasor diagram...
Realizing that j = e^{j\frac{\pi}{2}}, multiplying by j amounts to adding 90 degrees to the exponential. In elaboration of what berkeman has described:
V = L \frac{di}{dt}=L j \omega e^{j \omega t} = L \omega e^{j( \omega t + \frac {\pi}{2}).
The output voltage (V) is ahead (leads) the input current (I) by 90 degrees through an inductor. (Plot it and you can see). By analogous reasoning, you can show current leading voltage by 90 degrees across a capacitor.
yeah, I know where the phasor notation comes from. This description makes sense. Thanks a lot.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
