Optimizing Lever Arm Length and Material for Maximum Distance in a Mousetrap Car
For optimizing a mousetrap car for maximum distance, a longer lever arm is generally more effective, as demonstrated by a car that achieved nearly 100 meters. The lever arm's descent should be slow to maintain momentum, while a quick descent can lead to a rapid stop. Using a fishing rod string is recommended for its strength and flexibility, though any stable and lightweight material can suffice. The exact length of the lever arm and string can vary, but stability and weight are crucial factors. Overall, focusing on these elements can significantly enhance the car's performance.
decibel
am doing mine for distance should i have a long lever arm or a short lever arm, and how long should it be? and should i use a like a rubber string or just a normal one and how long should that be?
thanks if you can reply by today
Well, I have made a mousetrap car not too long ago so hopefully I can help. :smile: However, mine was very different from the rest of the cars, but it went 3m.
My friend's mousetrap car got the first place (almost 100m!) and his lever arm was very long. Also, I think he used a fishing rod string. When the mousetrap car was moving the leverarm went down very slowly, allowing the car to go further. If the leverarm goes down quickly, the car will also stop quickly.
Sorry, that's all I can remember... I just had a quick glance, I didn't look at it too closely.
wut kind of rod do u think i should use
a fishing rod?
Well, I don't *think* it really matters, as long as it's stable and not too heavy. :smile:
